SS-V: 3030 Heat Generating Plate
Test No. VT04 Find temperature at the mid-plane of a heat generating steel plate and the heat flow rate to the fluid the plate is heating.
Definition
Heat is uniformly generated in the plate volume.
The fluid temperature is 150 F.
- Properties
- Value
- Plate Thermal Conductivity
- 25 BTU/(hr-ft-F)
- Surface Convection Coefficient
- 13.969738 BTU/(hr-ft2-F)
- Volume Heat Generation Rate
- 1.e+5 BTU/(hr-ft3)
Results
A piece of plate is simulated by a 1 x 1 x 0.5 inch solid. Side surfaces of the solid are insulated in order to allow heat transfer only in the direction perpendicular to the plate surface.
Reference | SimSolid | % Difference | |
Temperature at Mid-plane [deg-F] | 299.1 | 300.0 | 0.30% |
Heat Flow Rate to Fluid [BTU/(hr*ft2)] | 2083.3 | 2084 | 0.03% |
